Results 1 to 5 of 5
Thread: On board charger and battery switch
  1. On board charger and battery switch
    Hi all. Have a question, my '16 Z3 has an on board battery charger. I assume the main battery switch should be set to "Off" position when charging?
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    26,973
    Boat
    Wired correctly, yes, switch needs to be in the off position.
    Mikes Liquid Audio: Knowledge Experience and Customer Service you can trust-KICKER WetSounds ACME props ARC Audio FlyHigh Custom Ballast Clarion LifeForm LED Polk Rockford And More
  3. #3
    Join Date
    Jul 2007
    Location
    Polk City, Iowa 50226
    Age
    47
    Posts
    1,506
    Boat
    08 RZ2
    Tigerbass,
    Don't want to highjack, so if you battery switch is one both it won't charge both? I kinda thought that is why one of those, not correct word transformer boxes is installed so it takes what ever is put into distributes it to all batteries. Im probably wrong.
    07 Escalade ESV
    08 RZ2 Blue
  4. #4
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    26,973
    Boat
    Tige should be installing 2-bank on-board chargers. So the switch needs be off for best charging and the 2-bank charger will charge both banks. However, if tige is using a single bank charger and wiring to the input post of the Pro Mariner distribute on demand, then in theory, a single bank "could" charge both with the switch off, depending on how its all wired. However, thats getting pretty cheap to do it that way.
  5. #5
    Join Date
    Jun 2015
    Location
    Southern OR
    Posts
    137
    Boat
    2015 Z3 with TAPS 3 / 2007 Calabria ProV
    My 15 Z3 came with a dual bank wired directly to each battery.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
