Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: New rev 10s DEAD
  1. #1
    Join Date
    Jan 2011
    Location
    Arvada, Colorado
    Posts
    1,241
    Boat
    2011 RZ2, Past 2003 22v
    New rev 10s DEAD
    Well within the 2 weeks of owning them there fried already! Hope this is a flaw in the speaker other wise Im far from impressed. My pro 80s/60s and 485 had the same power to them and never had any issues.. My rev8s also have the same amps on them and no issues..
    I will keep you guys informed with the results! $1,000 bucks for 4 uses not so good!
  2. #2
    Join Date
    May 2012
    Location
    Wichita, KS
    Age
    21
    Posts
    8,554
    Boat
    2004 Tigè 21i
    That f******* sucks man! I'm planning on getting a pair in the next month or so so keep us posted on if they send you some new ones! Hope you get it figured out soon, being without tower speakers sucks!
  3. #3
    Join Date
    Jan 2011
    Location
    Arvada, Colorado
    Posts
    1,241
    Boat
    Im not with out tower speakers my rev8s are still going.. but it sucks to have something I payed alot for quit so fast! Guess we are about to see how good there customer service is!
  4. #4
    what amp did you have running them?
    We have had very little if any issues with the REV's on defects on the drivers. So for a set to blow like that, something must be up.
    Our demo boat has two pairs off two SYN-4 for 400x2 and we play them, HARD. They are the first sets we built and we have been rocking the same ones since and not one issue
    Give Gyver a call at the office 877-938-7757. He can get you an RA to ship the drivers back and see what happened to them and a solution on what we can do. And help you figure out whats up.
    Tim
    Wet Sounds
  5. #5
    Join Date
    Jan 2011
    Location
    Arvada, Colorado
    Posts
    1,241
    Boat
    I have 4 kicker IX500.2s One to eack rev10 and rev8. Gains on the amps are set to 1/8 up 80hrz high button pressed on. I have tommys send them back in. I also had one of there empoyees out with me and he can vouche we were not even playing them hard.. They put off a weird smell from the second I turned them on! The rev8s still play great!
  6. #6
    Join Date
    Jan 2011
    Location
    Arvada, Colorado
    Posts
    1,241
    Boat
    There already on there way back to you guys. They should have left there store yesterday or this morning!
  7. #7
    Join Date
    May 2006
    Location
    Oklahoma
    Age
    29
    Posts
    51
    Boat
    2013 Tige z1 on the way
    I can vouche on their customer service , it's top notch. I had a syn 6 mess up from the get go and they took care of me in a very timely manner, now im back to rockin on the lake. It wasnt even their fault I got ahold of a bad one, it was one of their authorized dealers and they still took care of me. I wouldnt forsee you having any problems.
  8. #8
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    44
    Posts
    21,805
    Boat
    Quote Originally Posted by Wickedcummins View Post
    Giving off a smell is a good sign that something bad is going on. I think 500W may be a bit much when tuned low like at 80Hz. Just an FYI, the cross-over filter on the IX series is a 3 position slide switch, not a push button. I would just double check that its in the Hi-Pass (middle) and not to the left on Off. One with an issue would be odd but plausible, but both with an issue doesn't sound like a speaker defect.
    Yes sir =) with two rev 8s and two rev10s and three amps too them sould do the trick
    Am I reading correctly from your "Power" thread, that the Rev-8's are powered by a single IX500.2 amp, not one amp for each, like the Rev-10's?
    Mikes Liquid Audio: Knowledge Experience and Customer Service you can trust-KICKER, WetSounds, ACME props, ARC Audio, FlyHigh ballast & Barefoot Int, Alpine, Sony And More
  9. #9
    Join Date
    Jan 2011
    Location
    Arvada, Colorado
    Posts
    1,241
    Boat
    Quote Originally Posted by chpthril View Post
    They where I changed it and added another amp. The cross over switch is set to high and the hex at 80 is what the dude at wet sounds recommend. As for too much amp the dude I talked to at wet sounds I talked to before buying the amps said that would be a great amp and would make them sound killer. I mean its not like I had 1000 watts to each.
  10. I had the same thing happened, I had mine connected to a syn 4, but had gains up to high and burnt them. got them repaired and keep the gains not even 1/4 of the way up
  11. #11
    Join Date
    Jan 2011
    Location
    Arvada, Colorado
    Posts
    1,241
    Boat
    Quote Originally Posted by bwrag View Post
    Guessing the don't handle power like the pro series did
  12. #12
    Join Date
    Aug 2009
    Location
    Reno Ne VA duh
    Posts
    294
    Boat
    '11 MB Sports Team Wide Body 23'
    having the gains set too high means that they don't handle distortion, not that they don't handle power.
  13. #13
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    44
    Posts
    21,805
    Boat
    Gain setting has little to do with the wattage an amp produces
  14. #14
    A gain is not a volume knob or power knob. it does not make the amp put out more power the higher it is turned up. the higher the gain is the faster the volume ramps up based on the level. past a certain point "unity" setting, you get into an issue with clipping the amp easier. When running a lot of power, you have to be very careful with the tuning and set up and distortion.
    when running more power you gain headroom as you are able to run the gain down a little so the amp does not have to work so hard and you get a lot of power on demand.
    You can clip the signal from the head unit or eq into the amp. So the entire system as a whole needs to be looked at. from the source unit and settings. Flat on the head unit. No eq boost on a ipod, what downloads formats and compression the songs are at, eq settings, amp settings, gain settings. You can compound an issue with bad downloads from an ipod with treble boost or bass boost on sending that to a head unit with bass or treble boosted with a head unit at max volume sending a clipped signal to an amp. The amp is then set with the gain all the way or really high up, then the bass boost is on, then crossover too low or set to full range and so on. All of these can compound the issue. The speaker is at the end of the line and does what it is told to do. It reproduces the signal sent to it.
    So if all or part of that is going on. Then you can blow a driver. No matter how much power a driver can handle, speakers cannot take distortion.
    Too much power can and will blow drivers but 9 times out of 10 is is from the set up and not from over powering. which is why you always here the saying you are more likely to blow a speaker with too little power than too much. This is because with too little power, everyone wants more volume than what the power they have can give. So the gains are maxed out and the signal is maxed out trying to get that volume not knowing that it is not putting out more power, just clipping and getting louder faster. when running more power to a speaker, the gains wind up being lower because the amp can give more power. They are usually lower than the unity setting so putting out less power but since it is so much power, you gain that dynamic headroom and clarity. So less distortion.
    Tim
    Wet Sounds
  15. #15
    Join Date
    Jan 2011
    Location
    Arvada, Colorado
    Posts
    1,241
    Boat
    I don't listen to music if it's distorting I spent all the dough on my audio and like clarity. I have rims of money in all of our cars systems home system and garage system and boat system. Im not that guy who rails my stock speaker to where u can't hear what the hell is playing. I had one of Tommys slalom shop out with us and he will tell u the same this where no where near turned up. And believe me id burn the boat to the ground before I listened to a speaker that was sounding like ****. Just really weird the rev 8s are working flawlessly and are now tan off the two amps that blew the 10s. Switched em in the water thinking it was the amps. No smells fromthem and worked great for our morning set today. I've had these all season
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
