Page 1 of 2 12 LastLast
Results 1 to 15 of 23
Thread: Modify Trailer Bunks?
  1. #1
    Join Date
    Jul 2010
    Posts
    3,950
    Boat
    2009 24Ve w/ AutoWake, WakeTouch, and Ultra-Ballast
    2009 24Ve with 24Ve-specific trailer.
    There is a spot that would be convenient to mount the thruhull intakes for my ballast system. Unfortunately, the main trailer bunks are right on the edge of this location. Seems to me it would be better to optimize for the boat at the expense of the trailer, as long it doesn't compromise the trailer.
    The main (rear) bunks on this trailer are 2x6's that are supported every couple of feet by metal struts. I'm thinking about cutting out, say, 6-8 inches roughly in the middle of the bunk's length. I could add a galvanized crossbrace below the bunk to restore the mechanical integrity.
    This would essentially convert the trailer from a four bunk system to a six bunk system, and slightly increase the hull area that is not supported.
    Has anyone ever done this? Pros and cons? Terrible idea because...?
    Thanks!
  2. #2
    Join Date
    Feb 2007
    Location
    Lexington SC
    Age
    43
    Posts
    238
    Boat
    2008 24ve
    I would think it would be stronger and easier to simply remove enough material from the wood bunk to accomidate the through hulls. A cheap router and some new stainless steel carpet staples would do the trick.
  3. #3
    Join Date
    Jul 2010
    Posts
    3,950
    Boat
    I thought about that, and may still do it that way. But there's always a bit of "slop" when loading (a few inches of shift this way or that) and I don't want to crush the thruhull under the bunk. By the time I remove enough bunk to leave an adequate safety margin, it may be basically the same as cutting out a section and I'd have to reinforce just the same. That was the thought process that led me to ask the original question, anyway.
    I appreciate the idea. The fact that you came up with it too suggests it may be reasonable. I just don't know if it's better than a straightforward cutout of a few inches.
  4. #4
    Join Date
    Apr 2007
    Location
    Fort Worth, TX
    Posts
    1,113
    Boat
    2000 Tige 21V
    Now comes the fun part...doing all the work on the ramp parking area while the boat is in the water.
  5. #5
    Join Date
    Jul 2010
    Posts
    3,950
    Boat
    Quote Originally Posted by laserfish View Post
    I can launch the boat and pull the trailer around to our house to work on it there. No problemo. My big question is IF I want to mod the trailer bunks, and if so HOW.
  6. #6
    Join Date
    Jun 2010
    Location
    Spokane, WA
    Age
    41
    Posts
    7,432
    Boat
    2009 RZ2
    Do you float the boat on the trailer or power it on? I power it on and I would think that if you left a space for the thru hull fitting it would still drag on the bunk sliding on and off.
  7. #7
    Join Date
    Jul 2010
    Posts
    3,950
    Boat
    We typically "get it close", then manually pull it into place. Sometimes we have to use the winch if the trailer isn't far enough in the water. In that case, you're correct - the fitting would drag on the carpet. I'm not sure how much pressure would be involved, but it's not optimal.
    One thing in its favor is that we only launch and retrieve once per year, since the boat lives on an AirDock all season.
    I'm still evaluating options. Thanks for the feedback!
  8. #8
    Join Date
    Jul 2006
    Location
    Sturgis, KY
    Age
    36
    Posts
    7,237
    Boat
    2008 20V
    Quote Originally Posted by WABoating View Post
    Got any pictures of the boat on the AirDock?
  9. #9
    Join Date
    Aug 2006
    Location
    Thornton, CO
    Age
    44
    Posts
    11,267
    Boat
    Formerly an '07 RZ2
    I find it interesting that there are tons of boats on here that have ballast systems and they haven't done anything to the bunks to get it to work. There's a new 22Ve ballast install, his thru hull placement looks pretty solid. Is your trailer just that much different?
  10. #10
    Join Date
    Jul 2010
    Posts
    3,950
    Boat
    Quote Originally Posted by ajholt7 View Post
    Not yet. We bought the 24Ve at the very end of last season, put it on the water for one weekend while we still had the other boat on the AirDock, and then tucked the 24Ve into storage for the winter. It's now parked in front of my house getting ballast, etc. It will be a few more weeks before it's on the water. I'll definitely post photos.
    Thanks!
  11. #11
    Join Date
    Feb 2010
    Location
    Wyoming now, From Montana
    Age
    57
    Posts
    30,006
    Boat
    Current 2014 Z1 Former 2008 Z1
    Wab, Do you have pictures of how your ride sits on the Bunks? What brand of trailer do you have? That area on my Boatmate is wide open
  12. #12
    Join Date
    Jul 2010
    Posts
    3,950
    Boat
    Quote Originally Posted by Timmy! View Post
    I'm sure I have the same factory-spec'd trailer as other 24Ve owners. My difference is in where I'm trying to put the intakes.
    As mentioned elsewhere, the space under the floor near the v-drive is only about nine inches tall, so the normal factory location isn't ideal. (Tige uses plastic ball valves to shorten the pump stack.) I'm looking at other options.
    Right now, I'm considering the hull under the lockers themselves. I have the locker floor and factory foam blocks out, which opens up lots more volume for fat sacs - and also gives me an obvious place to put the intakes. However, the combination of hull strakes, engine mounting rails, and trailer bunks conspires to significantly narrow my location options. The bunk is the biggest restrictor, and the only one that can be changed, so that's why I'm considering it.
  13. #13
    Join Date
    Jul 2010
    Posts
    3,950
    Boat
    Quote Originally Posted by Iwndr View Post
    I have only one closeup at present, which doesn't really show much:
    Explaining things: There are two long bunks in the rear, ~8 feet long. They run from the transom forward and well past the area of interest, so they're the only ones that matter for this discussion. The photo shows they are just inside the hull strake, which runs from 7-10 inches on the tape measure. The area to the outside of the strake (inches 10+) is too high, and thus too close to the waterline, to insure the pump would stay primed.
    That leaves the area to the inside of the bunk (toward the right in the photo). This area is well under the waterline so priming would be fine. The problem is that the rail to which the engine mounts is about three inches to the right of the bunk. If I'm going to mount something there, I only have a strip about three inches wide to do it.
    Plenty of room, right? Yep, until you look inside:
    The tape measure is roughly in the same location here as in the previous photo. Now the three inch width become obvious. Still, it looks OK until you consider the side view:
    The other problem is the slope of the hull next to the rail. Anything mounted on the hull near that rail is going to be tilted toward the rail. There isn't enough clearance to mount a full height pump stack.
    This is why I was asking, in another thread, about 45 and 90 degree elbows. A 90 is the obvious choice, but a 90 elbow needs quite a bit of radius to spin onto the thruhull - and radius pushes me away from the rail and into the trailer bunk. A 45 elbow requires less radius but raises the pump closer to the waterline.
    Sorry for the long-winded response, but I wanted to be clear why I'm asking these questions. If I could get some extra space away from that rail - i.e. if the bunk weren't so close - I could space away from the rail enough to either stand the pump vertically or have enough clearance to spin a 90 elbow.
    Ideas and suggestions are gladly accepted... thanks!
  14. #14
    Join Date
    Mar 2010
    Location
    Huntsville, AL
    Posts
    90
    Boat
    2009 22 ve
    WA, Check out were I installed my thru-hulls/pumps.
    http://www.tigeowners.com/forum/showthread.php?t=14773
    I had to cut down one of the thru-hulls so the pump would fit under the floor but no biggie. I would think the 22ve would have the same amount of room there as your boat if not less. The 2 thru-hulls on the starboard side do not effect the transducer and the 1 on the port side didn't effect engine running temp. They are not directly in front of them.
    Mason
  15. #15
    Join Date
    Oct 2009
    Location
    Pennsylvania
    Age
    41
    Posts
    506
    Boat
    09 Z1 Alpha Z Tower
    Quote Originally Posted by Ewok View Post
    This comment was the first thing that came to my mind. I know you said you only put it ont the trailer a few times a year though.
    Friends don't let friends POWERTURN
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
