Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: New ballast
  1. #1
    Join Date
    Aug 2009
    Location
    Arizona
    Posts
    508
    Boat
    2002 20V RE
    New ballast
    Gotta thank mike for hookin me up!
    Heres a pic of one filled in each locker. Will get picks of the wave when I get it a little more dialed in. And vid once I figure that out! when it comes to working with video, Im lost haha.
    They fit well, conform alot to the locker. starboard side fills in under the seat a little, you can see how it slants down. Did on port side because I had the 7 gal jugs slid up under the seats.
    Planning on getting another tsunami pump to use to fill the 2 old 400# to put on the seats instead of the 7 gal jugs I have been using.
    Joey - Red 20V Riders Edition
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    44
    Posts
    21,789
    Boat
    Thanks for posting the pics Those look like they really fit good and filled pretty well. How full do you think they got? Maybe 3/4 at least! I was not sure how well they would fit being that they are sooooo much bigger then the locker.
    Mikes Liquid Audio: Knowledge Experience and Customer Service you can trust-KICKER, WetSounds, ACME props, ARC Audio, FlyHigh ballast & Barefoot Int, Alpine, Sony And More
  3. #3
    Join Date
    Aug 2009
    Location
    Arizona
    Posts
    508
    Boat
    2002 20V RE
    Quote Originally Posted by chpthril View Post
    Yea sorry it took so long, Ive had my list of crap to do and just hadnt gotten to it yet.
    I would say more that 3/4 full for sure, they fit almost perfectly width and height wise. My lockers are about 42" long, and the sacks are 50" long. and since they conformed pretty well i would say we lost about half of the 24x24x8 chunk that technically wouldnt fill. if you know what im sayin?
    I might be able to come up with some math for it, but i would guess that we are still at 1000lbs if not really close. 900's for sure.
    Wave felt killer, looked qaulity, but will be even better when its tuned in a little. looks nicest with taps around 4 and speed at 11.2
  4. #4
    Join Date
    Jul 2006
    Location
    Sturgis, KY
    Age
    31
    Posts
    7,231
    Boat
    2008 20V
    Let's see the plumbing.
  5. #5
    Join Date
    Jul 2008
    Location
    Cincinnati, OH
    Age
    30
    Posts
    762
    Boat
    2010 RZ2
    Seeing a totally full locker makes my mouth water....That is project number one for next year.
  6. #6
    Join Date
    Jun 2009
    Location
    Louisville, KY (Norris Lake TN)
    Age
    41
    Posts
    2,606
    Boat
    09 RZ2
    Quote Originally Posted by wallacmc View Post
    Here ya go!
  7. #7
    Join Date
    Jul 2008
    Location
    Cincinnati, OH
    Age
    30
    Posts
    762
    Boat
    2010 RZ2
    you're killing me, smalls
  8. #8
    Join Date
    Jun 2009
    Location
    Age
    41
    Posts
    2,606
    Boat
    09 RZ2
    LOL...that's what I tell my youngest son...
  9. #9
    Join Date
    Aug 2009
    Location
    Arizona
    Posts
    508
    Boat
    2002 20V RE
    Quote Originally Posted by ajholt7 View Post
    Here are 2 pics.
    Port side fill hose. 3/4"
    added the clear as an extension and so I could see the water flowing, just as a visual reference to weather pumps were working (getting old) and also added the valve. Same on the other side except I used nylon braided clear tubing after the valve (ran out of regular clear) and the valve is accessible from under the same cushion that allows you to get the main valve.
    Port side drain. Just got some brass fittings to make the pump work, added the nylon braided tubing as an extension because on the old sacks the pump mounted to the blue waterbed valve that was attached to the sack. Exactly same on the other side.
    Ok, so you may be wondering why I have those extra valves on the fill lines. we discovered that we could not fill just one side and have it stay full. We would fill the front and one side in the rear for surfing, and basically the sacks all equalized their pressures. Much like an old school level, a hose filled with water, the water will always be at the same level on either end of the hose. Dont you love physics!? The valve keeps the water from exiting from the fill lines and flowing into the other sack. Its not as big of a deal with the positioning of these new sacks, since the fill is explicitly on the top, but it keeps the front sacks from draining into the rears. Hope my drawn out explanation made sense.
  10. #10
    Join Date
    Aug 2009
    Location
    Arizona
    Posts
    508
    Boat
    2002 20V RE
    Quote Originally Posted by Guapo View Post
    Here ya go!
    you guys are nuts!
  11. #11
    Join Date
    Jun 2009
    Location
    Age
    41
    Posts
    2,606
    Boat
    09 RZ2
    Quote Originally Posted by somebodyelse5 View Post
    you guys are nuts!
  12. #12
    Join Date
    Jul 2006
    Location
    Sturgis, KY
    Age
    31
    Posts
    7,231
    Boat
    2008 20V
    Where did you put the intake and vents? What sack did you use up front?
  13. #13
    Join Date
    Jan 2006
    Location
    On an air plane
    Posts
    2,933
    Boat
    TIGE' 24V
    NIce system
  14. #14
    Join Date
    Aug 2009
    Location
    Arizona
    Posts
    508
    Boat
    2002 20V RE
    Oh gotcha you want even those haha, i can crawl under and take some pictures, the boat was plumbed when we got it so I didnt have to do any of that, but the intake is right a little behind the seat. Imagine if you could drop a line from the seat that went straight down, its about a foot behind that if I remember correctly. Drain vents are right under the rub rail, on starboard parallel with the bilge vent.
    Its late im tired, I hope that made sense haha.
  15. #15
    Join Date
    Aug 2009
    Location
    Arizona
    Posts
    508
    Boat
    2002 20V RE
    Some video with the new ballast, and 200# up front, plus 6 people, and three 7 gal jugs of water
    Towards the end of the video, speed at 11.5 taps at 4/5 I dont remember. Best wave we have ever had
    <object width="400" height="300"><param name="allowfullscreen" value="true" /><param name="allowscriptaccess" value="always" /><param name="movie" value="http://vimeo.com/moogaloop.swf?clip_id=13347104&amp;server=vimeo.co m&amp;show_title=1&amp;show_byline=1&amp;show_port rait=0&amp;color=&amp;fullscreen=1" /><embed src="http://vimeo.com/moogaloop.swf?clip_id=13347104&amp;server=vimeo.co m&amp;show_title=1&amp;show_byline=1&amp;show_port rait=0&amp;color=&amp;fullscreen=1" type="application/x-shockwave-flash" allowfullscreen="true" allowscriptaccess="always" width="400" height="300"></embed></object><p><a href="http://vimeo.com/13347104">Surfing Elevation 7-12-10 clip</a> from <a href="http://vimeo.com/user4132567">Joey Cavaretta</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
