#1
Old 02-08-2010, 03:51 AM
Fuh Sho's Avatar
Fuh Sho Fuh Sho is offline
Tigé Expert
Boat: 1998 2200i
new bump rails
is this possible to replace all of it? there is a big part of the left back corner broken off and the whole bow is all crooked.
advice comments?
ill shoot some pictures for yall to see when im talkin about
thanks guys
__________________
Everyone is entitled to their own opinion. It's just that yours is stupid.
Old 02-08-2010, 02:56 PM
yllw20 yllw20 is offline
Tigé Junkie
Boat: 03 20i
Sure can replace it. You can get it in long rolls. Make sure you have someone w/you when reapplying the rail it needs to be pulled tight all way around and is really a 2 man job.
Old 02-08-2010, 03:00 PM
Fuh Sho's Avatar
Tigé Expert
Boat: 1998 2200i
do i just use a heat gun to wrap it around the corners or is it pliable enough?
the rail on it now is rivited on there, whats the best way to fasten it down? same way?
__________________
Old 02-08-2010, 06:39 PM
lightning59's Avatar
lightning59 lightning59 is offline
Junior Member
Boat: 21iRiders Edition 2000
replaced both rub rail and insert on an old nautique I had. either a well heated shop or warm weather is preferred or you will be fighting it.
2 or 3 people and take your time and get it straight. very do it yourselfable! I used stainless countersink screws for new rub rail.
Old 02-08-2010, 06:53 PM
Fuh Sho's Avatar
Tigé Expert
Boat: 1998 2200i
where did yall purchace them?
__________________
Old 02-08-2010, 09:02 PM
Junior Member
if no marine retailer close, check West Marine online against your original rub rail. a call to tige' may lead to their vendor
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
